Issue with 2010 Inventor
when a rectangle is drawn with dimensions 44 wide by 79 height in inches it becomes a slanted rectangle. Other versions of Inventor I have used don't do that is there a way to fix it?
Curtis_W
Hi harris.1782,
You've likely toggled off your Constraint Inference and/or Constraint Persistence buttons.
This link from Paul Munford covers these tools and how they work:
http://cadsetterout.com/inventor/temporarily-turn-off-inferred-constraints/
Or you've turned off the inference for just some of the constraints.
Check this by right-clicking while in a sketch and choosing Constraint Options:
I hope this helps.
Good luck with all of your Inventor pursuits,
Curtis
http://inventortrenches.blogspot.com/
