Is this a bug - Inventor 2026
Paul-Mason
Message 1 of 9
Paul-Mason
I've ONLY seen this in Inventor 2026 not in any other versions
So here it is
When I highlight a part in an assembly RMB then click OPEN it doesn't open, The same happens when I use the file open icon on the top menu bar inventor shows the part in the relevant project folder BUT just will not open any files in the mine-browser that the file open icon on the top menu bar opens either . If I close then reopen the assembly then highlight then RMB - OPEN works fine same for the selecting file open from the top menu bar
@Paul-Mason Your post title has been modified to add the product name and version and to increase findability - CGBenner
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Replies (8)
Message 2 of 9
Yijiang.Cai
@Paul-Mason I can't reproduce the issue here. If possible, could you please provide the video or dataset for more investigation? In case there is the key thing I miss here. Many thanks!
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 3 of 9
kacper.suchomski
Hi
Please try this workflow - open assembly, select (LMB) any component, try open another component by RMB (without any other clicks).
Kacper Suchomski
Message 4 of 9
Yijiang.Cai
@kacper.suchomski  I can't reproduce the issue too when following the steps. If possible, could you please attach the video? Many thanks!
River Cai
Autodesk, Inc.
Message 5 of 9
kacper.suchomski
Please:
Kacper Suchomski
Message 6 of 9
SBix26
@kacper.suchomski 's video was helpful.  For what it's worth, I have seen this behavior as far back as I can remember.  It is annoying, but in my experience, it has been consistent.  When there is a component selection set active, a right click on another component does not change the selection, and the right click menu acts on the selection set, not on the component under the pointer.  It is not intuitive, but it is logical and consistent-- again, in my 23 years of Inventor experience.
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
Message 7 of 9
kacper.suchomski
I also remember this from many versions. But the author of this discussion mentions that he only sees it in the latest version, which is an interesting point of reference for me. 🤔
Kacper Suchomski
Message 8 of 9
Yijiang.Cai
@kacper.suchomski I got the behavior here, and it is a very very legacy behavior, and only happens in graphic window. When you have the same workflow in the browser, it will work fine. If the component in graphic window is already selected, the RMC on another component in graphic window will not discard the previous selection, but this will be discarded in the browser. That's the major difference.
River Cai
Autodesk, Inc.
Message 9 of 9
torbjorn_heglum2
@Yijiang.Cai , it is a legacy behavior indeed - personally I feel it most when working inside sketches. Typically when changing dimensions to driven or lines to construction, the object I RMB on do not change but some other do. Very annoying.
But the initial question remains unanswered, do you consider this to be a bug? I.e is this something that should be fixed?
Torbjørn
