ipt to stp or dwg conversion won't show up
This widget could not be displayed.
I am using Autodesk inventor 2008, and when I convert my part file to stp (via Save as) or dwg (via AEC exchange) and proceed to pull up the file in autocad, it does nothing (ACISIN command) or the file comes up as a blank (dwg). I tried changing the units of each to correspond, but that didn't work. What should I be doing?
Replies (0)
