Hi Dennis
Instead of crossing the River for Water (a Danish Idiom which translates
really badly!) - I would suggest you take a look at Task Scheduler, which is
already installed on your machine.
Go to: Start\All Programs\Autodesk\Inventor xxxx\Tools\Task Scheduler.
In the pulldown menus select Create Task - Export Files
Here I suggest you Press F1 to get help for selecting Project, Files or
Folder (the 3 small Icons), type of files to export and where to locate
them.
Below you select when you want to run the task and which options you need to
be setup. When ready click OK.
After the Task is done - you can create a report by right clicking on the
Task- and you can select only to see errors.
I hope this can get you started
Best regards
Uffe Bak
Autodesk Inc.
(dansker i eksil i UK)
