iProperties do not open correctly
finn_thiesse
finn_thiesse
Community Visitor
Community Visitor
After opening the iProperties in a drawing, only a blank window is visible. Once full screen mode is activated, you will see the iProperties. However, these can only be confirmed by pressing the Enter button - not left-clicking the OK button. If the full screen mode is minimised, again only a white field is visible.
CGBenner
@finn_thiesse
Hello, and welcome!
Did this just start to happen?  Are all of your graphics drivers up to date?
Chris Benner
johnsonshiue
Hi! This could be Inventor application setting related or display related. Go to Windows Display settings and select the recommended resolution and scale. Right-click on Inventor desktop icon -> Properties -> Compatibility -> "Change High DPI settings" -> check both boxes.
If it still does not work, use Inventor Reset Utility to reset Inventor settings back to install defaults.
Many thanks!
Software Test Engineer
CGBenner
@finn_thiesse Hello, do you still need help with this question?
Chris Benner
