iProperties - Custom
When creating an IDW drawing of a sheet metal item, it is possible to place text with the Text tool &
In the Format Text box, change the type of text pull down menu to "Sheet Metal Properties" and in the Parameter pull down menu change it to "FLAT PATTERN EXTENTS LENGTH" then click the "X" inset button, which gives you
<FLAT PATTERN EXTENTS LENGTH>
When you click on OK, the text gives you the length of the the sheet metal part.
My question is, how can I create a custom iProperty that will achieve the same result and also format the value to the precision that i require?
