iPart within iAssembly Changes After Placing iAssembly in Assembly
JAkeyEVG6G
JAkeyEVG6G
Hello!
While placing an iAssembly in an assembly, an iPart within the iAssembly forgets which iPart to use.
iAssembly 5563407 uses 4006107
In the midst of placing the iAssembly in the assembly, the correct configuration is shown translucently. The table also acknowledges the use of the correct part within the iAssembly (5563407 using 40061-07).
After the iAssembly is placed in the assembly, the iAssembly calls for a different iPart (5563407 now calls for 40061-03).
This is troubling. I have tried component replacing, deleting and replacing, etc.
What is causing this behavior and how can it be fixed?
Thank you!
johnsonshiue
Hi! The only logical explanation I can think of is that particular member file is out-of-date. It needs to be updated or regenerated. If it does not apply to your case, Please share the example that exhibits the behavior. It does not look right to me.
Many thanks!
Software Test Engineer
Type a product name
