A way to cheat is to activate a row then change the part material at the
part level. It (used to before R9) propagate back into the table.
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
wrote in message news:5005985@discussion.autodesk.com...
When I create an iPart with custom parameters for a feature Suppression
column it defaults to Compute but it would be nice if it also gave a toggle
for Suppress (maybe like it does when placing iPart in assembly).
Along those same lines if I create a column for Properties - Material I must
know exactly how available materials are spelled (and I assume upper and
lowercase, but I didn't check that). A list would be nice when creating
iPart. In addition there is no list when placing iPa
rt, that would be a secondary concern if I could easily select when creating
iPart.
