ipart Circular Pattern angle parameter in Inventor Pro 2016
hello,
In ipart circular pattern how to define angle parameter?
(eg. In Flange (ipart) want to add column for angle parameter for holes that will define angle between 2 holes
this is possible??
thanks.
mdavis22569
yes ...go into your F/X parameters.
Make custom values that you can adjust easily. Find the values for the hole pattern option in the dim' tree of F/X.  Put the custom name in the value...and now you can adjust it all as needed
Mike Davis
