iPart author Content Center with thread feature - Data types mismatch error
Walt_Jaquith
Walt_Jaquith
I'm having a weird issue that seems to be isolated.  A colleague has duplicated my steps and not seen the error...
-Create a simple part with a thread feature.
-Author the part for Content Center.  Everything works fine; the property mapping wizard automatically finds the thread designation and class.
-Cancel that and make the part an iPart.  Add the thread class and designation to the iPart table.
-Author the iPart.  The property mapping wizard doesn't find the thread designation and class, and when I try to add them, I get a "Data types mismatch" error message.
Anyone seen this?
Walt
johnsonshiue
Hi Walt,
The first thing I would check is to make sure you are using the same thread.xls as your colleague. Go to Get Started -> Project -> Folders Option -> Design Data. Is it the same as your colleague's setting?
If possible, please share the iPart with me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Walt_Jaquith
Hi Johnson,
I don't use the spreadsheet from the stock location, but I haven't changed it at all...
A few more points:
  • I have Inventor Pro 2020 and 2021 loaded on my machine.  They are both behaving the same.
  • I have created parts from scratch and had them behave the same
Here's a video of what's happening:
https://youtu.be/ssfo9JyJPzg
The part I've been testing in 2021 is attached.
Walt
johnsonshiue
Hi Walt,
I believe you are on 2021.2 update and 2020.3.4 update, right? If yes, this may be related to a known issue in CC Publishing workflow. Somehow the column equation was interpreted incorrectly. Please uninstall 2021.2 and 2020.3.4 update for now. We are working on a fix and it should be available soon.
I am very sorry for the trouble.
Many thanks!
johnsonshiue
Hi Walt,
This is similar to the following thread. It was reported as INVGEN-48039.
https://forums.autodesk.com/t5/inventor-forum/2021-2-update-issue/td-p/9868043
The fix will be available in the coming 2020.3.5 and 2021.2.1 update.
Many thanks!
Walt_Jaquith
That got it, thanks Johnson!
PCP7
Uninstalling the update fixed it for me. Thanks.
