Involute Spline generator
bhenderson
bhenderson
First up I am new to splines and gear, although I think it should be relatively straight forward.
For the life of me I can't get a spline feature on this shaft. Spline type/size/length etc.. is shown in pic. It previews which i know doesn't mean it will generate, and it doesn't 😞
Looking for any ideas as to what I am doing wrong. Have been at this all day and searched on forums and Machinery handbook and lots of other places.
Pack-N-Go attached of my effort so far. Only looking for the shaft spline ATM. Will do mating spline later in design run.
PDMC 2021
Inventor Build 353 Release 2021.3.3
Vault Pro 2021 Build 26.2.24.0, 2021.2.1 Update
Xun.Zhang
@bhenderson,
Click the fx button and turn to the calculation page, you will find the error message.
Try to fix it before generation.
Xun
bhenderson
Thanks for the input.
I don't understand what the Hub outside Diameter means. Have tried a few figures as 40, 50, 60 & 100 and all fail. Errors are shown below. Turning on Calcs seems to create more issues 😞
Can you elaborate please as the Help doesn't tell me much. Or can you add the spline to the dataset I supplied and upload it so I can see where I'm going wrong?
PDMC 2021
bhenderson
Found a video which gave me a clue. Need to select the orientation plane. Now it works. See the link below.
This is 1 component of Inventor that surely could do with a refresh. It's so not understandable!
https://www.youtube.com/watch?v=NDRyFAz99lo
PDMC 2021
