When i go to try an open up a .IPT or .IDW or .IAM in this directory I get the folloing error message. But all other directories work fine. see attached png file for error
Solved by Mark.Lancaster. Go to Solution.
Are the other directories under the folder called job # or somewhere else?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi! Did you activate the right project file? To view files properly in Inventor or Inventor View, you will need to activate the project so that files are properly loaded.
Many thanks!
