Inventor Vault recreating folders
I have one issue with Inventor Vault file save locations
I am creating new file (ipt and idw) in the below path
C:\Stewart_Vault\Designs\Engineering\Standard Drawings\03\DRAWINGS
When I 'check-in' this file through Inventor, Vault is creating another folder structure as mentioned below
C:\Stewart_Vault\Stewart_Vault\Designs\Engineering\Standard Drawings\03\DRAWINGS
Basically Vault is creating another folder 'Stewart_Vault' and recreating all folder down the line.
I am completely unaware how to solve this issue. Any help with the solution will be greatly appreciated
Rudresh
Mark.Lancaster
@Anonymous
In your Vault Client (Admin has to control this).  Is a working folder enforced?   If so what is it set to?   Under Vault Client/Tools/Option select show working folder.  Next select Project Explorer, what does it state there?
In Inventor under the Vault ribbon tab, expand "Access" and select Map Folders, is the correct mapping there.
In the end you have something mis-aligned in the mappings between Inventor, your local workspace, and Vault.
Update:  One more thing..  Make sure your active project file has the correct location set for your local vault workspace and you have defined a workspace.
Mark Lancaster
Hi Mark,
Thanks for your reply..
I have attached project file picture. Can you please look at this? I did not see any problem..
I checked location for working folder in Vault it shows
But I created this part in the path: "C:\Stewart_Vault\Designs\Engineering\Standard Drawings\03\DRAWINGS". This is where the file supposed to be.
But I am surprising when I check-in this file (through Inventor), Vault showing different location.
The major problem I am facing is when I open assembly file (where this part is used), It is giving ERROR saying Assembly cant find that part.
Rudresh
Mark.Lancaster
@Anonymous
Project file looks ok..
That means the mappings on the Vault ribbon tab/Access/map folders is incorrect or the working folder definition under (Vault Client) Tools/Administrator/Vault is not set right.  Are you the Vault Admin?
Mark Lancaster
Mark,
I am not Vault admin.
I will contact the admin to look into this issue. I think we may have to Install Inventor and Vault again..
Rudresh
Mark.Lancaster
@Anonymous wrote:
Mark,
Rudresh
There's no need to install either one of these applications.  You just have some incorrect settings.  Smiley Wink
Mark Lancaster
