Announcements
Inventor Unable To See Drawing Details In 3D PDF
I am unable to see all my details in 3d pdf please help me fix this issue.
Even though I am selecting the entities to be shown in the 3d pdf.
I am able to see only Part no, title, engineer, designer, revision number.
kelly.young has edited your subject line for clarity: 3d pdf
mcgyvr
What template are you using?
The template may not be setup to display the iproperties you have selected..
You will need to edit the template using a full version of Adobe acrobat
https://forums.autodesk.com/autodesk/attachments/autodesk/78/607168/1/customize_3d_pdf_template_v4.p...
johnsonshiue
Hi! Could you tell us what Inventor release you are on? Please install all the applicable updates to your release. Did you use an assembly 3D PDF template or a part 3D PDF  template? Could you share an example exhibiting the behavior?
Many thanks!
Software Test Engineer
I am using Autodesk Inventor 2018 and I am trying to create both assembly and part files into 3d PDF.
mcgyvr
As I stated above the template you are using will only show those title/partnumber/revision/designer/engineer/notes section in the PDF page because thats how the template has been designed..
The other iproperties that you check are included in the PDF but not on the actual page..
If you want them on the page you need to create a new template or modify the one you are using to have the additional field data.
The PDF link I gave above shows you how to modify templates to add more information..
I'll post it again just because..
Click here to learn how to modify the PDF templates to add additional fields..
But see.. All the other data is included.. Just not where you thought it would be or how you though it would..
