Inventor Tube and Pipe Run
RJR89
RJR89
Using the tube and pipe run environment, can pipe systems be modeled then exported to .pcf to allow Plant 3D to generate ISO's?
Mark.Lancaster
@RJR89
T&P exports to ISOGEN .PCF file format https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
Not sure what Plant 3D will do with them but I will tell you the ISOGEN output lacks information and may not produce the results that you're looking
Mark Lancaster
