Inventor to Online Viewer Model Browser configuration
Christo_van_Wyk
Christo_van_Wyk
When creating design views from Inventor to the Autodesk online viewer, is there a way to not show the solid in the lowest part of each part in the model browser? Please see attached.
It is for a project, and we do not want the client to be able to go to that level of the model browser.
Thanking you in advance and kind regards,
Christo
CCarreiras
Do you mean the part list?
You can upload a model to the viewer with the part list disable.
...this way your partner will not have access to the model contents, only view the model, measure, slicing, etc.
CCarreiras
Christo_van_Wyk
Hi @CCarreiras ,
I was told by the engineer, that they do not want the client to see the line in the browser that reads: 'Solid 1', but they still want them to see the Part number. I do not think it is possible to hide that level, but would like to find out if that is in case correct?
johnsonshiue
Hi Christo,
I believe the workflow is still being further enhanced. In the meantime, you may want to export the assembly to DWFx or JT file. Then use Autodesk Design Review (DWFx) or JT2Go (JT) to view the design.
Many thanks!
Software Test Engineer
Christo_van_Wyk
@johnsonshiue
Thank you very much for the info. I'll give that a go.
Kind regards,
