Inventor to Maya workflow
I want to export an assembly into Maya so a colleague can create animations using my model. I use design view representations to control visibility of various parts, and its essential for my colleague to be able to use these in the animation. Does anyone know if this is possible, and what is the best workflow to do this?
Cheers
Mark.Lancaster
@Anonymous
Maya supporting import file types: https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-ManagingScenes/files/GUID-69BC066D-D4D8-4B12-900C-CF42E798A5D6-htm.html   So if anything matches with Inventor export file types..  Well go from there and see..
Mark Lancaster
DarrenP
also read this: https://forums.autodesk.com/t5/maya-forum/how-to-import-inventor-2019-file-types-into-maya-2019/m-p/...
there is not an easy way of doing this
like what was posted in the above link you may have to go through 3ds max first
DarrenP
