I have found various posts about importing models from Creo to Inventor, but nothing about the other way around.
Does anyone have a good best practise for that? We are talking about Inventor 2022 to Creo 7.0. That means Creo cannot import Inventor files directly because 2022 is not supported yet.
Requirements would be that the file name can be transported, maybe also material naming. Important to the customer is also weight and center of gravity.
I tested a bit, so far STEP looks most promising. However some details are not working. For example weldment assemblies.
Weld beads have a material assigned in Inventor and are also exported and imported as solid bodies. However they have no density in the exported STEP file. I'm not sure if that's intended.
