At the risk of taking this further than it needs (although maybe of interest to some other posters): I've never used Viewbase (or Solview), but I assume if they come from a solid model. to read such an AutoCAD drawing, you would need the solid model in your file path somewhere. if so, from the point of view of providing customers with an AutoCAD drawing, that would be a non-runner.
What my company does is to provide a 'layout' drawing, giving key dimensions, but NOT the dimensions of every single piece part. The customer can then use this acad file as a basis to work up their own, fully detailed drawings, using their own standards for layers, linetype, etc. We are providing our customers with a design, NOT a full detail draughting service. So we either give them a 'proper', but not fully dimensioned AutoCAD drawing, which they can work up into a detail drawing of their own, or alternatively we would have to fully dimension in Inventor, in which case, a pdf of the Inventor drawing would suffice for them. Some customers *might* be satisfied with '90%' dimensioned pdf drawing, plus a step file or similar as back-up, others wouldn't. Personally I have found in the past that the workflow of exporting into AutoCAD, especially regarding the scale of detail views and the dimensioning thereof, is a time-consuming process. And always, when you go from something 'smart' to something 'dumb', close document control is needed to prevent divergence between the model and the AutoCAD drawing.
