Inventor to Acad - walkthru
ian_taylor_contractor
Observer Observer
Message 1 of 9
Observer
Observer
Can you tell me if a dwg / model created using Inventor with multiple ipt files / assemblies can be saved & loaded into autocad so that the model can be viewed / walked thru etc
Replies (8)
Message 2 of 9
Can you tell me if a dwg / model created using Inventor with multiple ipt / assembly files can be saved / loaded into autocad so that the model can be viewed / walked thru etc
Message 3 of 9
CCarreiras
You can open an Inventor DWG file In Autocad, but You can see only the first sheet.
If it's only to open, measure, check something, that's ok.... but...
If you want to edit the file and save it in Autocad, you will lose the associativity between Inventor 3D and 2D models in that file.
I suggest you Export Inventor DWG to Autocad DWG to have all the sheets.
You can do changes To these files without messing with the original source file.
CCarreiras
Message 4 of 9
Observer
Observer
Thankyou for your assistance
Message 5 of 9
kacper.suchomski
Export assembly as IGS file and open in AutoCAD.
Kacper Suchomski
Message 6 of 9
johnsonshiue
Hi! It is indeed supported in AutoCAD. It is called Inventor Link. Please take a look at the AutoCAD Mechanical Help page.
https://help.autodesk.com/view/AMECH_PP/2024/ENU/?guid=GUID-1D4EC142-438E-49DF-A72E-27A69D075BC0
Besides this workflow, you can also create associative drawing views to Inventor ipt and iam file in AutoCAD. The command is called VIEWBASE.
Many thanks!
Software Test Engineer
Message 7 of 9
jtylerbc
I'm not sure if you meant "dwg" as the literal file extension ".dwg" or not.  But in case you did, I wanted to clarify something that I didn't see anyone else mention.  In Inventor, the file extension .dwg is only for the actual 2D "paper" drawing.  The 3D models are contained in part and assembly files (.ipt and .iam).  This is a very different file structure from AutoCAD, where Model Space may contain either 2D or 3D geometry, and then Paper Space layouts are contained on different tabs in the same file (which is a .dwg file).  In Inventor, the .dwg would only be the equivalent of the Paper Space layout from AutoCAD, and thus there would be nothing to "walk through".
This is why @CCarreiras was referring to "sheets".  If you mention "dwg" to an Inventor user, they typically will assume you are talking about a 2D drawing file, and not a 3D model (unless they are also an AutoCAD user).
It would probably be the highest-level assembly file that you would want to "walk through".  There are several options for getting geometry from Inventor to AutoCAD.  Some have already been mentioned here.  There is one method I would add.  @kacper.suchomski mentioned exporting a .igs file and then importing it into AutoCAD.  This works, but is usually unnecessary.  For many years now, the IMPORT command in AutoCAD has been able to directly import Inventor part and assembly files, so there is typically no need to go through a neutral format like IGS or STEP to get there.  This takes your geometry straight from Inventor to AutoCAD without the extra step of the .igs file in the middle.
Message 8 of 9
Observer
Observer
Thankyou for your feedback and advice. Much appreciated.
Message 9 of 9
Observer
Observer
