Inventor Studio - reversing animation?
patrick.odonoghue2
patrick.odonoghue2
I have a 10 second animation of an assembly that involves a rotating and moving shaft. Once the rotation and movement is complete, I would like to reverse the movement and make that part of the animation.
Is there an easy way to simply mirror created animations, or will I have to programme the movement manually again?
Adots
@patrick.odonoghue2 If you are looking for a simple way to play the animation in reverse, there is an option to reverse play all of your animations. Unfortunately, there is no way to copy and paste existing tweaks.
Alex Dotseth
Technical Specialist
WHolzwarth
No big deal.
German Spiegeln is in English language  Mirror.
Select the sequence and right-click it.
Walter Holzwarth
Adots
I should have clarified. @patrick.odonoghue2 What version of Inventor are you on? The capabilities differ depending on version.
Alex Dotseth
patrick.odonoghue2
Brilliant, that's perfect, thank you! @Adots I'm on Inventor 2020 but I have it resolved now, thank you
