Inventor Studio human eye point of view
This widget could not be displayed.
See attached. I have a camera set up in the operator's cab of a crane & the target on the end of the boom. I want to render still shots/animations of what the operator would see with the human eye. Other than the perspective option, is there a zoom angle, depth of field or any other setting that would give me the human eye perspective? Or at least close?
Also, I should be seeing the edges of the windows & some of the inside of the cab. There seems to be a certain distance around the camera where everything gets cut off. Why is this?
Thanks.
Replies (8)
yannick3
Hi
RMB camera browser node
select edit, change the view to perspective and all option you need will be available
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Thanks for the response. I'm aware of the edit camera options. I'm wondering what the zoom angle needs to be to represent what the human eye would see. Or if there are more settings I'm not aware of. And more importantly, why everything around the camera is cut away in the "view inside cab" jpg.
Thanks.
yannick3
Hi
Can you post the data set ?
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Probably a stupid question here, what's the data set consist of?
Thanks.
yannick3
Pack and go or all assembly file(part and sub assembly) in one folder and zip
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Zipped folder is still 9mb. Too large to post correct?
Thanks.
jtylerbc
Have you tried actually rendering the inside cab view?  Generally when I have a situation like this, objects too close to the camera are being cut off in the Inventor graphics window, but actually show up as expected when the image is rendered.
Yes, it rendered correctly. Half of my problem solved.
Thanks jtylerbc.
