Inventor Stress Analysis
Hello! Need your help
I'm using Inventor Professional 2021 to verify the contact pression between 2 cylinders (parts and assembly attatched).
For that I tried to block the axe of the inner cylinder and impose a displacement of the outter cylinder towards the inner-one (until bothe axes are collinears), but I didn't find the option for a displacement control. The inner cylinder diammeter is larger than the inner diammeter of the outter cylinder, so I expect elastic deformation in both cylinders.
I tried to use the dynamic simulation too, to impose the displacement and later evaluate the stress, but I couldn't make any component move the way I want (move from this pointA(x,y,z) to this pointB(x,y,z)).
For the model, I'm using axisymmetry in 30° because I don't know how to model just the section.
If anyone could help me, I'd appriciate.
If you have another idea of how to measure this contact pression, please tell me.
Thanks in advance!
TheCADWhisperer
It might seem counterintuitive, but you do a Prescribed Displacement with the Fixed Constraint.
Thank you very much!
