@Anonymous wrote:
Thank you very much Cris, you made a great help for me in this video, I now can control the scale of stress range, but... there is one last question:
Why when changing force magnitude the stress scale changes automatically? I mean stress limits must be relevant to the part geometry, material and design, not the force magnitude so when apply force that exceeds these limits a failure indication will show up like red color.
I think you must have miss understood stress colour scale. It is not to indicate failure but to present results only.
Whether something is a failure or not is for you to judge, as computer only does calculation for you.
FEA is just a tool like any other. Computer will not know if stress of 500MPa is big or small for your case.
For example. If I do FEA for elements made of S355 steel that has yield strength about 350 MPa. It is for me to judge if stress of 5000MPa that come up is acceptable. And whether it is or not depends on the analysis I do. Sometimes I may decide it is OK because it is only present in parts of the model I am not interested in and have very cores mesh that combined with simplified boundary conditions gives very high local stress.
And in other cases I may decide that it is way to much as it concerns areas of the model I am analysing and result is not coming from numerical causes but from construction being overloaded.
Colour scale is there to let you judge and asses more easily.
But remember assessment and decision and responsibility is always yours.
FEA software is no a magic solution that tells you if you construction can withstand the load. It is only a method for calculations, and a method only. Depending on what you will put in to it it will produce results, but it cannot be ever allowed to think for you.
In my careerer I saw many times when engineers have trusted FEA not being able to asses the results. It is scary.
I also witness results of such approach on construction sites. It easily costs lives.
When I than after was asked to do analysis of the causes I was devastated by lack of responsibility and basic knowledge in some designs.
So
Do not ever let computer judge. Use it as a brainless hummer.
If someone gets hurt it is YOU who has to live with this for the rest of your life.
Cris.
Cris,
https://simply.engineering
