Inventor Forum
Inventor still running in task Manager after closing. Will not allow save.
8 REPLIES 8
Message 1 of 9
Brian.Price
591 Views, 8 Replies
I've seen other releases of Inventor have had issues with the process hanging in the task manager but I am unable to find out why 2021 is doing it and if there is a fix.
When I close Inventor 2021 there is an "Autodesk Inventor 2021" process still running in the task manager. If I open the file I was working on it opens a new Inventor and when I try to save it says that it is still open. When I close the old process I can then save the file.
It does this for every instance of Inventor that I open. I tried running as administrator and that had no affect either.
8 REPLIES 8
Message 2 of 9
sgwilliams
in reply to: Brian.Price
Try this to see if it fixes your issue:
  • Open Inventor
  • Use it as you normally would.
  • Then when your ready to close it hold the ctrl key down on your keyboard and click the "X" in the upper right corner of the Inventor Window.
This is a default application window reset that you can use with any Microsoft OS since Win98. It's worth a try, probably won't fix it but stranger things and all that.
Work Station : Custom built, Liquid Cooled, Asus Pro WS X570-ACE Motherboard; AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor; ASUS TUF Gaming NVIDIA GeForce RTX 3060 V2 OC Edition Video Card; 32 GB CORSAIR Dominator Platinum DDR4-2132 Memory ; Samsung 850 EVO 1TB SSD Drive.
Message 3 of 9
Brian.Price
Thanks for the tip, unfortunately it didn't work.
Message 4 of 9
f_calebh
This happens to me all the time with 2020. Vault thinks I have two sessions of Inventor open and it's because there's a background process that didn't end when closing out of the Inventor application earlier in the day.
Message 5 of 9
Brian.Price
in reply to: f_calebh
I've had it happen before when I used 2018. But this is happening every time I close Inventor. I'm currently working on 21 different files with various different projects. So it's a lot of annoyance.
Message 6 of 9
johnsonshiue
Hi Folks,
Could you confirm that you all run Vault? Does it happen if Vault Add-In is unloaded?
Many thanks!
Software Test Engineer
Message 7 of 9
in reply to: johnsonshiue
No, I am not using vault. I'll check to see if it's installed but I don't believe it is.
Message 8 of 9
Brian.Price
Vault isn't being used, and vault isn't installed.
Message 9 of 9
hansDPQMN
in reply to: sgwilliams
works perfectly
