inventor simulation
inventor simulation
nzaem1992
Message 1 of 8
inventor simulation
nzaem1992
please ... how can apply weight load of body in this model ... Annotation 2020-04-21 091526.png
Replies (7)
Message 2 of 8
admaiora
Just enter in the stress analysis enviroment. Apply material, fix base faces, apply force.
Pay attention, your model can be subjected to buckling, and Inventor doesn't support buckling analysis. (Nastran IN CAD can do it).
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 8
nzaem1992
this model has 10 section i applied forces in every section ... now i want apply the weight force of body on body for make sure if rectangular beam (legs) can endure all this force .. thanks alot   323.png
Message 4 of 8
admaiora
is this the first time do you use this enviroment?
You can enforce your fundamentals with stress analysis in Inventor here:
https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/20...
Admaiora
Message 5 of 8
nzaem1992
not my first time .. but now i make design for work ... i need make accurate design ... in model i put the force acting in body ... but body weight also act in body i want put this weight force for make accurate simulation
Message 6 of 8
JDMather
I would use Frame Analysis and activate Gravity.
Attach your assembly here.
Message 7 of 8
nzaem1992
i am very confuse ... if i use inventor simulation for make linear static analysis to Make sure part endure lift loads ... why i need buckling analysis ? .. what is difference between buckling analysis & linear static analysis ??  ... @JDMather  @admaiora
Message 8 of 8
lena.talkhina
Hello @nzaem1992  !
Great to see you here on Inventor Forum.
How things are going? Did you find a solution for this project?
Let us know if we can help you more
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
