Inventor Simulation Help - Fix a Node
Hello all,
I am working on running some simulations on a metal disc. I'd like to constrain the part in the Y axis (easily done with the fix command in vector form), and then fix one node in all 6 degrees of freedom (translational and rotational). How do I fix one node? The constraint options only apply to faces or edges. Thanks!
mwighton
In the part file create a point and use that as the fixed node.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
raviburla
For applying contraints, vertex/edge/faces are valid choices. So in order to fix a node, you will need to create a geometric vertex at the location where the fixed constraint needs to be applied. A vertex can be created by splitting a face (or any other geometric operation) if the vertex does not already exist. The meshing engine ensures that a node is always created at geometic vertex.
Ravi
Ravi Burla
Sr. Principal Research Engineer
