Inventor sheet number issue.
Good day,
One of my colleagues working on the same project as I am, encountered a peculiar problem this morning. He is busy with a drawing (idw) detailing some steelwork. The steelwork is a right and left hand assembly. He detailed the one side already, and created 11 sheets in the drawing. Then to create the other side, he basically saved it as the new drawing, and using "Replace Model Reference" updated the views to reflect the opposite assembly. Everything went well until he had to create an extra sheet to reflect some additional detail.
So right click and selected "New Sheet" expecting the sheet to be added to the bottom of the list with the number 12 next to it to indicate its place as the 12th sheet in the drawing. What surprised us was that the numbering started at 1 again. Doing it again, created another sheet, this time as another sheet 10. See the screenshots included. The problem is that you cannot delete these errant sheets. If you drag them up the hierarchy, their numbers change, but now the bottom sheets take over the incorrect numbering.
Creating a new drawing, and adding sheets did not recreate the problem.
Opening the same drawing on another pc, same issue. So it is related to the specific drawing, and not to a new drawing or the specific workstation.
We fixed the drawing by creating a new drawing and copying the sheets over to the new one, one at a time. No issue with the new drawing.
We are working on Inventor 2021 latest updates installed, Vault Pro 2021, Win 10 Pro.
Anyone ever came across this? Any ideas as to what can cause this?
Regards
Kobus
