Inventor - Sheet metal - Fold
I have a piece of folded sheet metal. folded in 3 parts.. i changed to thickness of the metal plate and all 3 folded feature didn't work. I tried sketching it again and it wou'dnt fold again. Don't understand.
Thank you!
Lydia
JDMather
Fold is almost always the wrong way to model a sheet metal part.
Your Sketch1 appears to be imported geometry, not dimensioned and the Origin Center Point is not in a  symmetrical location.
There are no foldes in the part you attached.
There is an Extrusion feature - a poor choice for sheet metal beginner - use the Sheet Metal tools.
Your part thickness is different than the Sheet Metal Style Thickness variable.
Your Sketch1 is more complicated than it need be.  (do a Show All Constraints)
Work Axis 1 is not needed.
Sketch6 is not constrained.
Can you attach your version of the part with the folds - before you changed the thickness?
I recommed that you model sheet metal parts in finished form, rather than trying to fold a flat and guessing at finished dimensions.
