Inventor sheet metal flat pattern work flow
emanuel.c
emanuel.c
I've encountered this issue many times and it is frustrating. After using CUT on a bent flange, the flat pattern gives me more than a single edge, in other words it is not a square edge. I understand the thinking behind it, that it's what would happen in real life, however for the purpose of cutting that flat pattern on a machine having two edges is not helpful at all. The machine always throws errors because of overlapping or opened lines or splines etc. I would much rather it gave me a square edge, either the inside or the outside one.
Could I change anything in the design work flow or what could be done to avoid this. Any thoughts are appreciated!
Accepted solutions (3)
JDMather
Set your Cut feature to Cut Normal or Cut Across Bend as appropriate.
AdamAG99T
I think clicking the "cut normal" option in the cut dialog box should accomplish what you want. It will cut the bent part in such a way that the flat pattern ends up without the odd edges, however this does result in a slightly distorted bent part.
JDMather
@AdamAG99T wrote:
... however this does result in a slightly distorted bent part.
...realistic bend.
emanuel.c
Thank you! That's what I was looking for.
