Inventor Sheet Metal Chequered Plate Appearance To Single Face Only
lkirit2000
Advisor Advisor
lkirit2000
Hi I give a chequered plate appearance to sheet metal, it appeared both sides. But I need to apply only top surface. How I can do that ?
kelly.young has edited your subject line for clarity: Chequered Plate
YannickEnrico
When you choose the appearance without having anything selected, it changes appearance for the whole part.
What you want to do, is to left click the face. Then right click -> Properties -> Appearance.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
SBix26
... or select the face(s), then select the appearance you want from the Appearance drop-down.  No need to open the Properties box unless you want to change other properties as well.
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
lkirit2000
Thanks for your response. Is there any way to change the shape and chequered pattern ?
Rgds
kelly.young
Autodesk Support
Autodesk Support
Hello @lkirit2000 take some time to mess around with the Appearance Browser and it will help your models look much nicer.
Here's the help link that should be useful:
About Appearances
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
