Inventor Rotated Entire .idw Drawing Sheet Somehow?
Please help me. I am don't understand.
kelly.young has embedded your image and edited your subject line for clarity: Rotate list, help
Xun.Zhang
Hello Mark,
How can you do that? Could you tell me how to create a view like this from scratch? I am able to create such kind of sheet rotation via internal API and there is no way to get the sheet rotate back to normal.
The workaround more like -
Create a new sheet, drag all views to the newly created sheet and delete the rotated one.
https://autode.sk/2l4Kxj9
Hope it helps!
Xun
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Are you using a 3D mouse like a 3D Connexion device?
Mark Lancaster
SER4
I am not able to reproduce this behavior with a 3D Connexion SpaceNavigator on 2019.
It would actually be helpful to be able to rotate the entire paper/camera in drawing environment.
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
diego_dorta
hello,
yes that's the point!
a user reported that once set a shortcut for his 3d mouse (to manege the view cube) he used it in idw and the view flipped just like in the 3d space.
the odd is that there is no way to set it back to the right view angle (now he sees the sheet from the back side).
do you have any suggestion on how to go back to the correct view?
nb: copy the sheet to a new file doesn't fix, couse the sheet is still flipped. so I think that the information is stored in the sheet.
thank you
Jeeles
Observer
Observer
Try F5  previous view.
