inventor rectangular pattern issue
bastien.gentesQB3BV
bastien.gentesQB3BV
Hi, I'm working on floor tiles and I have to add a non-slip pattern on it
problem the tiles are not rectangular it means the pattern have to stop at some point (attached files)
And I would like  inventor to stop creating the pattern out of the piece.
There is a feature called "crucial" that might be the answer to my problem, but no matter what I'm doing it seems I can't make it work
i hope someone have a fix
kacper.suchomski
Hi
You have 2 ways:
  1. Find the items in your browser and disable the instances.
  2. Create a point pattern in the sketch, then change the omitted points to normal (non-construction). Finally, use a sketch-driven pattern.
Kacper Suchomski
johnsonshiue
Hi! This is something we are working on. It is called Boundary Pattern. Please sign up Inventor Feedback Community (https://autode.sk/InventorBeta) to try the workflow on the latest internal build in an install-free environment.
Many thanks!
Software Test Engineer
Alexander_Chernikov
also you can try to use full rectangular base and full pattern,
then create the working plane with nesessary slope and use Split
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
bastien.gentesQB3BV
Hi, thank you for your responses.
as I had not so many instances wrong, I disabled the problematic ones inside the rectangular pattern fonction
