Inventor Professional fails to install on Windows 10, please help!
Message 1 of 39
 Hello!
I am a student and new to inventor and have used it on a previous school computer, however it will not install on a new computer i just purchased. I have zero idea why it fail, but have attached the Installation Log File. I would greatly appreciate any help that you're willing to provide. Thanks so much in advance!!
-Zac
Replies (38)
Message 21 of 39
I can't install AutoDesk Inventor 2018 and i have done everything you said
Here is the the install log
Message 22 of 39
Mark.Lancaster
@Anonymous
The log has no information.  What happens when you install?  Any messages?  Is it stuck somewhere?
Mark Lancaster
Message 23 of 39
It happens this then i click ok and it closes
Message 24 of 39
Mark.Lancaster
@Anonymous
That's why its important to share that so we can provide a solution..  Smiley Wink
Most users have resolved the issue using the workaround #1 option in this article: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Installation-error-referencing-SecondRun-and-FirstRunThreadId.html
Mark Lancaster
Message 25 of 39
Workaround #1 worked out fine , thanks !!
Message 26 of 39
Hello again, i tried to install the programe on the computer of a friend of mine and she has a different problem, here is the log
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Message 27 of 39
Mark.Lancaster
@Anonymous
Is this your copy of Inventor you are trying to install on your friends computer?
Update:  Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include yours or someone else personal information such as the serial #. This is a world wide user forum and that type of info should not be included in your posting or part of the log file that you attached from your friends machine.  So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
I would recommend this: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-remove-and-reinstall-Microsoft-Visual-C-Runtime-Libraries.html and then try the installation again.
Mark Lancaster
Message 28 of 39
No, it is her own copy inventor, just helping her out with the install
Message 29 of 39
Dear Mark
I am having problems with Inventor 2016. I had it on my computer for more than 2 years, today I opened it and it say license expired. I logged on my account and tried to insert the one I had there but it kept on saying the license was not ok.
I then decided to unistall the program, reboot the system and tried to install it again. But if I do so it says "some products failed to install". And i have no clue what to do... i am really struggling and need the program!
Would you be able to help? I have attached the windows that pops up to tell me the installation failed and the log file.
thank you very much
Message 30 of 39
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Is this based on a student license?  If so most likely it has expired since student license is only good for 3 years.  Meaning you will need to go back here https://www.autodesk.com/education/free-software/featured, select Inventor, sign in with your Autodesk/Student account and request a new version.  You will not able to use the same version that you have now.  But let us know if this license is based on an student license..
Mark Lancaster
Message 31 of 39
Dear Mark
yes it is a student license and I installed it in january 2016 that´s why it was weird that it already expired in june 2018.
If I go to https://www.autodesk.com/education/free-software/featured, and select Inventor 2016 (of course being signed in), it tells me a new serial number and when i try to install inventor it gives me the problems I posted before.
I don´t know how to solve this.. I cannot install anything
Message 32 of 39
Mark.Lancaster
@Anonymous
In the end your download is simply failing due to the method you're using..
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
Message 33 of 39
Dear Mark
I have the same problems as before. Should I try installing a more recent version? I tried with the Preferred method.
best
Message 34 of 39
Mark.Lancaster
@Anonymous
Your log is still showing you're using the web installer..  If you actually did the preferred method your log would show something different.
Mark Lancaster
Message 35 of 39
But that´s how AVA told me to install. It doesn´t appear a "scroll" section on the right of AVA so if I follow what she says I do the web installation.. there is NO other way. Did i do somehting wrong? I mean the window is clearly different then the one in the article you sent me.
Message 36 of 39
Mark.Lancaster
@Anonymous
Sorry, AVA's interface is always changing...  Meaning that article would have to change every day..  Smiley LOL
Just type download
Type Inventor 2016
Select I have an existing license and follow the prompts
At the end select browser download and download each part..
Mark Lancaster
Message 37 of 39
Dear Mark,
instead of using AVA i used the browser installation method and it worked!
Thanks so much, you are really helpful.
best
francesca
Message 38 of 39
I have tried and tried to download Inventor 2016 Pro on my computer, Surface Pro running Windows 10 Pro, even falling your instructions on this post but still get only failed attempts.
Please help.
Message 39 of 39
johnsonshiue
Hi! The install log indicates it is .Net 3.5 install related. Inventor 2016 required .Net 3.5. Without it, the program would not be install correctly or run correctly. Please install .Net 3.5 on your machine before restarting 2016 install.
Many thanks!
Software Test Engineer
