Inventor Professional fails to install on Windows 10, please help!
Message 1 of 39
 Hello!
I am a student and new to inventor and have used it on a previous school computer, however it will not install on a new computer i just purchased. I have zero idea why it fail, but have attached the Installation Log File. I would greatly appreciate any help that you're willing to provide. Thanks so much in advance!!
-Zac
Replies (38)
Message 2 of 39
Mark.Lancaster
@Anonymous
Welcome to the community...
Your download is failing due to the method you're using.
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
Message 3 of 39
Thank you so much! That worked perfectly 🙂
Message 4 of 39
I'm trying to install inventor 2017 and on the installation screen it shows autodesk inventor 17 and the revit  failed. How do I fix this? I went thru your link to download with browser. Thanks for the help.
Message 5 of 39
Mark.Lancaster
@Anonymous
Your installation is failing due to the
Microsoft Visual C++ 2008 SP1 Redistributable
So I would recommend uninstalling all version of the Visual C++ Redistributable on your machine (Windows Control Panel/Add&Remove programs) and then restart the installation again so that it can put them back on.   Most likely you have a newer version than the installer needs.  Report back on your progress.
Mark Lancaster
Message 6 of 39
I am having the same issue. I uninstalled all the Microsoft visual redistributables and let the installer tool add them but I keep getting a failed installation. Attached is the log. Thanks!
Edited by
Discussion_Admin
Message 7 of 39
Mark.Lancaster
@Anonymous
Your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
1. Access the Autodesk Virtual Agent and follow the download links to your product.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Although you were probably unaware of this, but when you post or share stuff here, please make sure it doesn't include your personal information such as your serial #. This is a world wide user forum and that type of info should not be included in your posting. Granted the installation log file helped us to determine your root cause (but it did contain your serial #)... So in the future remove or blur it out before posting. I will have the moderator remove it in order to protect your information.
Mark Lancaster
Message 8 of 39
This worked, thank you very much I appreciate it!
Message 9 of 39
I'm having a similar issue installing Inventor. I have tried installing both 2016 and 2017, with no luck. Any advice?
I have attached a copy of the 2016 install log.
-Oscar
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Message 10 of 39
Mark.Lancaster
@Anonymous
So did you read any advice that was already here about when posting your log file?
I assume not because you shared your serial # with the entire world..  Its right in your attached log file.  Smiley Wink
Now to your issue, your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Mark Lancaster
Message 11 of 39
I have the issue with windows C++ redistributable failing to install, I tried uninstalling it through control panel and that fixed nothing. I also tried during it through install agent and the initzialing bar doesn't move then it just closes.
Message 12 of 39
Mark.Lancaster
@Anonymous
Without your installation log file we can only speculate what the issue at this point. Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Mark Lancaster
Message 13 of 39
I'm having a similar issue. I don't want to post my setup log with all of the serial numbers, however. What do they look like? Are they the "SN #######" or are they the {#####-#####-#####-#####} numbers? Thanks!
Message 14 of 39
Mark.Lancaster
There will be a line that has s/n followed by the number. It maybe in the log numerous times or not in there at all
Mark Lancaster
Message 15 of 39
Here is my setup log. Thanks for any help. My computer crashed and I had to hard reset it during the setup and now I can't uninstall what it did install.
Message 16 of 39
Mark.Lancaster
@Anonymous
Perform a clean uninstall per these instructions.  Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine.
Next you are using the web installer which is unreliable.
1.  Clean out your personal temp (%temp%) folder.  Set Windows UAC to never notify, full admin rights and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product.  At this point you could cancel the installation or create a deployment.
Mark Lancaster
Message 17 of 39
I can't delete the program files folder because it is in use. And I have no idea where. I looked in the resource monitor and couldn't find anything. Here is a screenshot.
The installer won't let me select Inventor because it thinks that it is still installed. Above is the only step I couldn't complete for the uninstall. Thanks for your help.
Message 18 of 39
Mark.Lancaster
@Anonymous
Have you rebooted your machine and try again to delete?
Mark Lancaster
Message 19 of 39
I have tried to reboot and it is still in use. I have also attempted to force delete the folder through the cmd and that also fails.
Message 20 of 39
Mark, your suggestions sadly did not help in my case. I've even gone so far as to try it on a completely fresh Win10 install with UAC and Windows Defender disabled - still the genskf.exe window appears and progress bars stop filling.
Last part of log file below:
MSI (s) (A8:CC) [02:14:51:037]: Note: 1: 1402 2: UNKNOWN\Installer\Products\195DD4F746221000000017707DF0D34B 3: 2
MSI (s) (A8:CC) [02:14:51:037]: Executing op: UpgradeCodePublish(UpgradeCode={4868C376-2264-0001-0000-9375FC6A8759})
MSI (s) (A8:CC) [02:14:51:037]: Executing op: SourceListPublish(,,DiskPromptTemplate=Autodesk Inventor 2018 [1],,NumberOfDisks=1)
MSI (s) (A8:CC) [02:14:51:037]: Note: 1: 1402 2: UNKNOWN\Installer\Products\195DD4F746221000000017707DF0D34B\SourceList 3: 2
MSI (s) (A8:CC) [02:14:51:037]: Executing op: ProductPublishClient(,,)
MSI (s) (A8:CC) [02:14:51:037]: Executing op: SourceListRegisterLastUsed(SourceProduct={7F4DD591-2264-0001-0000-7107D70F3DB4},LastUsedSource=C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\inventor\)
MSI (s) (A8:CC) [02:14:51:037]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (A8:CC) [02:14:51:037]: Specifed source is already in a list.
MSI (s) (A8:CC) [02:14:51:037]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (A8:CC) [02:14:51:037]: Adding new sources is allowed.
MSI (s) (A8:CC) [02:14:51:037]: Set LastUsedSource to: C:\Autodesk\Inventor_2018_English_Win_64bit_dlm\x64\inventor\.
MSI (s) (A8:CC) [02:14:51:037]: Set LastUsedType to: n.
MSI (s) (A8:CC) [02:14:51:037]: Set LastUsedIndex to: 1.
MSI (s) (A8:CC) [02:14:51:037]: Executing op: ActionStart(Name=RunGenskf.8CAA0058_0064_2018_BE3C_0382C62FEAD5,,)
MSI (s) (A8:CC) [02:14:51:037]: Executing op: CustomActionSchedule(Action=RunGenskf.8CAA0058_0064_2018_BE3C_0382C62FEAD5,ActionType=3138,Source=BinaryData,Target=mitsi2018 "C:\Program Files\Autodesk\Inventor 2018\Moldflow\data\mitsi.lic",)
