Inventor Professional 2022 hanging up at the launch screen
Message 1 of 8
I have installed the Inventor professional 2022. After installing when i try to open the Inventor, it's hanging up at the launch screen. I thought there might be some problem with the downloaded files, I deleted the existing files and downloaded the new files. I have downloaded and tried to re-install the files several times but no use.
Please suggest me a solution
Replies (7)
Message 2 of 8
Gabriel_Watson
I've only seen this happen when license issues happened, so you can try the section "Register software to the Autodesk Licensing Service" on the following page:
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
I know it does work in some cases, so definitely recommend giving the time to try this approach.
Message 3 of 8
I have tried all the solutions provided in this link but nothing worked out. My issue did not solve.
It is still hanging up on the launch screen
Message 4 of 8
JDMather
Do you have these three files?
Can you post a screenshot that shows the full size (I have obscured the size in my image attachment).
Message 5 of 8
Yes, I have all the 3 files
Message 6 of 8
Gabriel_Watson
It is strange that you received no error messages. That makes finding a solution much harder...
In my bag of tricks I know that if you had an error saying "VBA failed to initialize properly. Please restart Inventor." during launch, or "Inventor is not able to detect VBA (Visual Basic for Applications) on your system" the fix would be to look in your local (C) drive for "VBA*.msi" and reinstall VBA from the package you find.
Other comparable solutions I have are all for Vault Pro not launching, but since those issues are similar in that they sometimes give us no error prompt, I would say it is harmless to try a few:
- Uninstall Autodesk Desktop App;
- Vault Professional 2020 error on launch/startup "Connectivity.request.runtime.util.requestruntimeexception (....... long error prompt): reinstall both x86 and x64 versions of the multi-installer Visual C++ 2015, 2017 and 2019 redistributables (NOT THE ARM64 one).
https://support.microsoft.com/en-us/topic/the-latest-supported-visual-c-downloads-2647da03-1eea-4433...
- Errors when launching Vault: "Insertion index was out of range. Must be non-negative and less than or equal to size. Parameter name: index" and afterwards "Object reference not set to an instance of an object.". For this one, we usually replace the 4 main executable files in the Vault / Explorer folder (Autoloader.exe, Connectivity.VaultPro.exe, CopyDesign.exe, JobProcessor.exe) with fresh ones from a working PC.
Therefore, for Inventor I would hope you have any colleague you could copy their "Inventor.exe" from "C:\Program Files\Autodesk\Inventor 2022\Bin" to replace your own. I cannot attach my Inventor.exe here due to forum regulations.
Message 7 of 8
JDMather
How did you start the installation process?
(By double clicking on 001 of 003?)
Message 8 of 8
i started installation by right-click on 001 file and then run as administrator
