Inventor Forum
Inventor Professional 2019 Crash on StartUp
9 REPLIES 9
Message 1 of 10
2087 Views, 9 Replies
Problem:
You have installed Inventor Professional 2019 on a computer/laptop that meets or exceeds required system specifications but when you run it,it crashes and you are prompted to send an error report to Autodesk in a form.
The same Inventor runs on other computers without a problem.
Solution:
I made the following tutorial to help you fix/solve the problem in  a Windows environment.
Respond here with any questions that you may have or if you need further assistance.
Video:
https://www.youtube.com/watch?v=QM10JgQGn8k
Peter K'onunda,
ICT Officer/Autodesk Technical Representative,
Numerical Machining Complex Ltd,
Nairobi-Kenya.
9 REPLIES 9
Message 2 of 10
Cadmanto
I'm sorry, is your issue resolved?  Or are you still having problems?
Looks like you are posting a solution on youtube for those having a similar issue.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
johnsonshiue
Hi! A few possibilities. Please make sure .Net 4.7 is enabled or installed on your machine. Update graphics driver and install all critical Windows updates. Or, it could be license related. What licence do you have? Please send the crash report with your email address and then send me an email (johnson.shiue@autodesk.com). I would like to take a look at the report and understand the crash better.
Many thanks!
Software Test Engineer
Message 4 of 10
in reply to: Cadmanto
Thanks a lot for the feedback.I was however giving a solution that worked for me.
Thanks once again.
Peter K'onunda.
Message 5 of 10
in reply to: johnsonshiue
Thanks a lot for your response.The issue was resolved.I was just sharing my solution with anyone who might need it.
Peter K'onunda.
Message 6 of 10
mdavis22569
hi @Anonymous
What was the solution ....so others might be able see and use it if needed.
If it was one of these ... you might want to accept that for an answer.
Mike Davis
Message 7 of 10
The original posting was based on the solution @Anonymous used to resolve the issue.  OP was just sharing their findings..
Mark Lancaster
Message 8 of 10
in reply to: mdavis22569
Installation of .Net Framwork was the solution as shown in the video at my YouTube Channel
Video:
The video above shows how I solved my problem.
Peter.
@mdavis22569 wrote:
hi @Anonymous
Message 9 of 10
marius.gildehaus
Hello @Anonymous!
Please hit the Accept as Solution button if a post or posts solves the issue.
Thanks!
Marius Gildehaus
Technical Sales Specialist
Message 10 of 10
Hello Cadmanto,
I was only posting to help someone who may encounter such a problem.My problem was solved months ago when I made the video and uploaded it on YouTube.
Reagrds,
Peter.
@Anonymous i7-6700 @ 3.41ghz
Inventor Pro 2018
y
