Inventor Professional 2017 2D Sketch Constraints Change Line Colors
Hi guys,i'm not getting the constrains in 2-d sketching.The line or 2d sketch changing colours like green and blue what does it mean?.kindly help me .
kelly.young has edited your subject line for clarity: Inventor Professional 2017
Cadmanto
RC on your sketch tool bar and select.
As far as the sketch changing blue/green, sounds like maybe your color scheme in what ever one you have setup in the application options.  Please post a screen shot of what you are talking about for this.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! I am sorry I don't understand the question. Is it about constraining not working or you don't understand the color change? Do you mind sharing an example here?
Many thanks!
Software Test Engineer
Hi, thank-you for replying,i didn't get the both constraints and the colour
change too.
johnsonshiue
Hi! I looked at your prior postings I think I know where the issue is. You are not new to Autodesk products (AutoCAD and Powermill). But, you are new to Inventor. I suggest you may want to start with Inventor tutorials or Youtube videos. You may want to focus on 2D Sketch related workflows.
Inventor 2D Sketch is dimension and constraint driven. It means that each line or point can be constrained to a location or relative to other geometry. If you change the dimension or the constraint, the geometry will move accordingly. The change in color denotes if the given geometry is free to move or not. It is for reference purpose only. In some cases, a piece of geometry cannot move but it bears the color to move or vice versa.
Many thanks!
Thank you so much @Anonymous Shiue
