Inventor Forum
Inventor Forum
Highlighted
Post 1 of 14
Inventor picture becomes too dark
306 Views, 13 Replies
04-27-2012 11:21 AM
Hello
My Inventor screen picture became much dark as used to be.
For example all my aluminum parts became too dark and too grey.
My office machine has excellent picture within the same settings of Lightings.
Here is video link attached. If I set more Bright the picture becomes closer as used
to be but it used to work fine at 50% and my office machine is also perfect at 50%
Please advise ether it about the setting of Inventors or my videocard ?
I've got this problem after the successive series of program crushes.
There is only Inventor has this "dark picture" problem. Other programs works fine.
Inventor reinstallation did not help.
Please help,
Orest Yavtushenko
Post 2 of 14
Re: Inventor picture becomes too dark
04-27-2012 04:06 PM in reply to: Orest_iy
Orest,
I did not see your video link. You also don't state what version of Inventor you are on.
So you checked the definition of the lights in the Style editor and they have the correct intensity?
Bob
Bob Van der Donck
Principal UX designer DMG group
Post 3 of 14
04-27-2012 11:25 PM in reply to: bobvdd
Ouch
Here it is
http://www.screencast.com/t/oMFXQKmw
Yes it is the correct setting in Lighting style.
And I used to have a nice picture prior to crush
If I switch from Two Lights to Default and other settings they are also dark.
It seems like some one more general Lighting correction exist and it is located in front
of all other setting affeting them all.
For example I should set Brightness aprox 70% at my laptop now while my office machine
within this shining more than too much..
Orest
Post 4 of 14
04-30-2012 03:53 AM in reply to: Orest_iy
Orest_iy, are you aware that most laptops operate with reduced screen brightness, to save power?
This may explain why your desktop machine looks great but the laptop does not. Try adjusting the screen brightness on the laptop. This may be a BIOS setting or a Video card driver setting or simply a control panel/Display setting.
If you run your laptop on battery power at all, that will also have an impact on screen brightness.
My suggestion would be to live with the default styles, and remind yourself that you are working on the laptop Smiley Sad
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Post 5 of 14
04-30-2012 07:29 AM in reply to: trumpy81
Hmmm
It could be the reason but I have only the working window of Inventor dark.
The Inventor ribbons, browser and other programs works fine.
I do not think the ability of  laptop to save a power in this selective way is so advanced...
Either way all possible setting of my nVidia card I set to default or to disable.
The choice of aplication vs nVidia guiding the screen does make any difference.
For instance my prewiew pictures of files I did not touch after this problem are much more bright
compare the files saved now..
Orest
Post 6 of 14
04-30-2012 07:35 AM in reply to: Orest_iy
What are your settings in tools..application options..hardware tab? (on both computers)
2017 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Post 7 of 14
04-30-2012 07:54 AM in reply to: mcgyvr
In the Application Options - Display
I have tried both aplication and document setting.
I the Document Settings - Standard - Settings I have the same light settings
I have restarted the Inventor each time of setting were changed.
If I switch between Default - Two Light and other - all are much more dark as used to be
Both PC has same settings.
I prefer application setting so the Inventor will dictate the Light but not the current file.
After this problem I've tried probably all possible combinations and even reinstall the Inventor
Post 8 of 14
04-30-2012 08:12 AM in reply to: Orest_iy
Is this happening with just this one document, or does it happen with all documents?
Regards
Andy M
Post 9 of 14
04-30-2012 08:18 AM in reply to: trumpy81
All files of all projects became dark.
It is really like some setting are located BEFORE all existing in Inventor
and something turn them 30-40 prcent down
Post 10 of 14
04-30-2012 08:35 AM in reply to: Orest_iy
When you Installed Inventor on the laptop and opened the files for the first time, did you get a message dialog asking to convert existing styles to appearances?
Regards
Andy M
Post 11 of 14
04-30-2012 09:54 AM in reply to: trumpy81
No I have not.
Here is something really specific and unusual question.
I have much installation and reinstallation of Inventor I would definetelly draw attention for that...
Orest
Post 12 of 14
04-30-2012 10:22 AM in reply to: Orest_iy
I looked at the video again, and I think you are running Inventor 2011, is that right?
Regards
Andy M
Post 13 of 14
04-30-2012 10:34 AM in reply to: trumpy81
No it is 2012. The 2011 used to have less lighting possibilities but also less problems with that.
I also find my nVidia 3D setting intended exclusively for Inventor but setting to default gave no result.
The mentioned features are mostly greek for me but I just tried to shift them all out of default and
also without any result.
I have attached the screenshot
Orest
Post 14 of 14
05-01-2012 07:16 AM in reply to: Orest_iy
My problem is solved.
It has gone after the setting to default the 3D NVIDIA setting for Inventor.
I used to do it several times without result but the trick is this time I have reset
not only Inventor but Inventorview settings.
NVIDIA Control Panel - Manage 3D settings - Autodesk Inventorview - Restore.
I do not know what they ment under the Inventorview but this work out.
I am also did not make any changes there except after this problem, I am spent
a while to realize some settings could exist beyond the Inventor itself.
Inventor is just one program making this HP Mobile Workstation 8740 i7,RAM16G,
NVIDIA Quadro 2800,1G machine to crush.
The video driver sometimes crushes but popup the message it is restored
but everything working after that except the working screen of Inventor.
Orest
Inventor Exchange Apps
