Inventor Performance - running heavy iLogic code
Could someone recommended where be the best place to start when upgrading some hardware to improve performance?
Our models are roughly 600MB in size and contain about 1000+ parts. We are using iLogic to change part sizes/materials/colours, suppress features, replace components etc
General modelling is ok, its the execution of iLogic code which takes longest and the opening of large assemblies (Inventor is opening them in express mode)
Current setup is:
Dell Precision workstation
Intel Xeon @CPUE3-1220 v3 @ 3.10 GHz
16GB RAM
Windows 7 Professional 64 bit running on 226GB HDD
AMD FirePro V4900 Graphics
Autodesk Product Design Suite 2015
mcgyvr
Faster processor speed... more/faster RAM....
While the ilogic is running check task manager to see whats being "taxed"
Mark.Lancaster
@Anonymous
I'm not saying swapping out existing hardware for better components is not the way to go but you also need to look at your Inventor settings and model for performance improvement as well.  Here are some things to consider
Okay maybe I went a little over-board..  Smiley Very Happy
Mark Lancaster
Thank you both for your responses.
@mcgyvr I've been given the green light to spend a bit on a new CPU and more RAM 🙂 is this a good website to use for heloing in my choice of CPU? http://www.cpubenchmark.net/singleThread.html
@Mark.Lancaster I will try to go through as much of your list as possible.I recently cleared out lots of files on my workspace and temp files and switched off all the fancy windows settings and noticed a difference.
Someone has suggested a SSD to replace my HHD, would this be of more benefit compared to a faster CPU/ more RAM?
