Hi there,
I created a multi body part and then used the Make Part command to export the outermost dimensions of the object. For extracting/exporting, I made use of the illogic codes and its working find.
The issue is the part is orientated in a certain angle and the extracted dimensions are calculated based on the bounding box. Please refer the images attached.
Anyway to re-orient the model to the bounding box or extract the true lengths of the model?
Any help would be appreciated.
Also, is there any way to extract dimensions from the measure tool ?
Images
Part : Orientation of object with the bounding box
Part1 : Dimensions with the illogic rule
Part2 : True dimensions with measure tool
Cheers !
kelly.young has embedded your images for clarity.
