Inventor Offset Tool Not Working Properly
Hello again,
Could you also work with your team on the Offset tool not working correctly? When I type in my initial amount to offset, the line just drops wherever and I have to re-submit the Dimension before it goes to the correct location. This is an important tool and could be a costly mistake if unnoticed.
Thanks!
kelly.young has edited your subject line for clarity: Mirrored ipt. using Defaul-ANSI instead of Custom Style
Curtis_Waguespack
Hi @Anonymous,
See this recent, related topic:
https://forums.autodesk.com/t5/inventor-forum/dimensions-with-offset-wrong-in-2d-sketch/m-p/7609510#M672489
I hope this helps.
Curtis
kelly.young
Autodesk Support
Autodesk Support
@Anonymous what version and update are you currently working with?
Do you have Snap To Grid on?
Please select the Accept as Solution button if a post solves your issue or answers your question.
johnsonshiue
Hi! There is indeed an issue here. A fix has been worked on an internal build. It will be available in 2018.3 Update. When the Beta becomes available, please feel free to try it if you are a Beta user.
Many thanks!
Software Test Engineer
Thanks! I did figure it out, my Snap was on but this still shouldn't happen.
