Inventor Nesting Utility + Microstep MG plasma
paul_skiejka
paul_skiejka
I have a question, if using this software, I will be able to create nest and NC program for MicroStep MG plasma cutter.
Its that kind of plasma cutter:
Podobny obraz
I cant find any post process for it.
Regards
swalton
I haven't used the Nesting Utility yet so I'm guessing.
It looks like the as-designed workflow is to generate a .dwg/DXF from the Nesting Utiltiy, then use the some other CAM tool (Inventor HSM, TruNest, Software from Plasma Cutter Vendor) to generate the tool paths.
See http://help.autodesk.com/view/TNNUINV/ENU/?guid=GUID-AE0A867C-C106-417A-8975-2AFF2DE8BB35
What is your intended workflow?
If you want to use Inventor HSM, I'd take a look here for the available posts: https://cam.autodesk.com/hsmposts
If they don't have what you need, try this link: https://forums.autodesk.com/t5/hsm-post-processor-forum/hsm-post-adjustments-needed-find-your-right-...
Steve Walton
Inventor 2025
Vault Professional 2025
jeff.godfrey
Yep, Steve is exactly right. The Nesting Utility is responsible for building nest pattern(s). Those patterns can then be sent from NU into Inventor HSM for posting / NC code generation (or, some other CAM tool if needed).
Jeff Godfrey
Software Development Manager
paul_skiejka
Inventor HSM/Trunest for posting / NC code generation could be nice solution but as I said i cant find any post processor for MicroStep Mg plasma cutting machines.
Right now we are using software from microstep for nesting/generate nc code but its demo version and its almost expired.
I just thought that if we already have licenses for Autodesk Inventor(nesting utility included), we will be able to use it as nesting software and to generate nc code.
Can you help/guid me to create/modify the post on my own. This machine use .cnc files.
Regards Paul
swalton
I'm not going to be much help with modifying a post-processor.
Try the HSM forums here: https://forums.autodesk.com/t5/hsm/ct-p/213  There should be some people who can help point you in the correct direction.
Or follow the third link (in my first post on this thread) to see what options are available to get a custom post written.
Steve Walton
Inventor 2025
