After creating an .iam of woodparts, all of the from laminated board created through Woodwork for Inventor, I try to creat the nesting but after giving it the origin file it freezes, sometimes at 14%, sometimes at 89%, sometimes even started the percentage.
Everything is up to date, updates, and so on...
Is maybe a RAM problem?
0lá!
Check if you have disk space at the C: drive. (it will be used temp files to load the parts)
If the parts are sheet metal, set the providers to open only sheet metal parts (or Inventor Part if they are solids), disable the other options.
Place the files in a local PC folder instead of an external device.
Can you share the files so we give them a try?
131 GB is more than enough 🙂
I will take a look at the files now...
Well.... your case is a different one, you are creating assemblies from "Woodwork for Inventor" multisolids.
When importing, Inventor will see that as Generic CAD (i don't know why), so you have to set the provider as Generic CAD also.
Nesting doesn't manage well assemblies with that kind of parts (derived links, etc), we hope that some development in this area will improve the workflow.
From now, what i advise is to carry the sources (Parts) manually, and not selecting by assemblies.
Be aware that you have to set the number of parts you need to nest.
Tip: carry the source parts in groups, not all at once.
Carry, let's say 20 parts, check if all went well save the file, and carry more parts.
This way will be easier to identify any part with troubles without losing all the "carry work".
HI!
It works... Great!
But... woodwork will give you options that Inventor Nesting doesn't have, like the wood grain direction, and the ability to rotate parts in the nesting (as you need and not as the program chooses), also you can prepare other features like circular saw rips, special wood slots, that you can export for the cutting/cam machine.
Inventor Nesting is more used to sheet metal cutting, woodwork was designed for woodworking.
Anyway, Inventor Nesting it's better than nothing.
To be fair, W4I is not just a plugin for cutting boards, but a suite of woodworking software. This and more convenient modeling and BOM, taking into account the different coatings, edge bands, etc.
Nesting for Inventor is not developing for some reason. Small fixes once a year and no more. The usability of the program is on par with the programs of the early 2000's. The nesting function constantly freezes and hangs on complex parts. There are interface bugs and a lot of inconvenient things.
