Inventor Model will not show up on drawing when section is on.
Hello All,
Here is what is going on. I have a drawing that has been perfectly fine up until now. One of the parts in the assembly had a hole feature moved to the 180° position. In doing such, I rotated it 180° in the assembly. Opening the drawing, I get an error message:
Some Components could not be processed properly resulting in a view that may not be accurate.
The attempted Cut View operation resulted in some problems while processing IPXXXXXX-01.ipt;. Problematic components are excluded from the cut.
The model excluded is a spring with Section Participation on. When I change the Participation to None, the error messages go away. I get no errors in the assembly itself.
I have tried replacing the model with itself. I have tried different view representations. I have tried recreating the view with a new view. All of these things will not cause the spring to show up, only turning the section participation to none.
Any help would be much appreciated, thank you.
Autodesk Inventor 2012.
