Inventor- missing logo after exporting to Autocad dwg
I have a problem with exporting Inventor idw into Autocad dwg format. I couldn't find a solution on this forum.
After the export, the logo is missing. The export option works fine for all of my coworkers. I have no clue what causes this problem. If i ask anyone else to export the original .idw file it works fine so it seems that the problem is located on my computer.
I attach the .idw file, the .dwg i get after the export and a screenshot of what i see.
Please help me. What can i do to fix this?
Thanks in advance.
Replies (20)
alexanderboogaard
For anyone seeing this article:
The root cause of this problem is the association for *.bmp to Paint.Picture. This has to be set in the register settings. But this is not all. You also have to make sure that MS Paint is installed as well.
In Windows 11 it is not installed by default anymore, so you should install it from the Microsoft Store:
Paint - Free download and install on Windows | Microsoft Store.
For Windows 10 users, you can install it from:
Uninstall and reinstall Paint and Snipping Tool - Microsoft Support.
This resolves the following article as well:
A drawing with an embedded image exported from Inventor 2023 to the DWG file contains a blank spot i...
Kind regards,
Alexander Boogaard
