Inventor Make Parameters / Dimensions Dependent On Each Other Within Assembly
Hello, I'm looking for a way to make parameters / dimensions dependent on each other.
Best in an assembly. Sodas I can change only one length of a component and all other lengths of the other components adapt to.
Could someone help me with that?
kelly.young has edited your subject line for clarity: Question
TheCADWhisperer
Attach your assembly here.
johnsonshiue
Hi Theresa,
There are primary two ways to do it. You can create a skeletal part or an Excel table with all the parameters you want to drive. Then you link the part (or the Excel table) to the assembly and all the parts you want to create within the assembly. In this way, any change to the skeletal part or the Excel table will propagate to all part within the assembly.
Another way is to use iLogic rule in an assembly. In an iLogic rule, you can easily access all parameters in each component within the assembly. You can do things like Parameter1 in PartA equals to Parameter2 in PartB.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Here are a few links that should help you out.
To Create a Derived Part or Assembly
Adaptive geometry
Set Part Parameters in Assembly
If you want to attach an example with Pack & Go that would be helpful for experts to comment on further.
Please select the Accept as Solution button if a post solves your issue or answers your question.
