Inventor Large Assembly Drawing Performance TOO SLOW
Message 1 of 24
I'm DYING! I'm trying to make a drawing of a large assembly but my computer is STRUGGLING to function... This can't be normal. I have a BOXX computer that is only about a year old. There's no way I can live with it taking so long to open and do any normal/typical commands.
I've searched for this issue but it doesn't seem like anything truly works... I could really use some help with this.
Please and thank you!
~Shawn
Replies (23)
Message 21 of 24
blair
If all the files reside with a single project file it's easy to have Windows display/sort by date. Then just copy the current modified files back to the server.
I use a utility program call "ViceVersa". It allows a date/database which will sync files back and forth based on their date. I keep the same file/folder structure on my laptop and home office machine as at work.
I'm able to keep all the files properly updated based on their dates on each of the machines. Much tougher having to go through each fold and file and manually doing it. We don't use Vault as I'm the only user of Inventor.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 22 of 24
I'm going to look up that software now. I need to figure out how to get back onto the server today. Thanks!
Message 23 of 24
BeKirra
Pack & Go is very straightforward to me.
Addition to what others have suggested and based on your description, there are something you may need to take care of
1) Pack & Go to your local folder.
    Ensure the "Keep Folder Hierarchy" option is selected.
2) Pack & Go to network server
    Also ensure the "Keep Folder Hierarchy" option is selected.
Take a small assembly file for practice if you are not confident.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 24 of 24
S_May
If they work so, it will get back quickly..
Please test, and Feedback...
