Inventor is showing wrong colors
Darkforce_the_ilogic_guy
Advisor Advisor
 We have a problem at look a lot like this, but the color is only wrong when we open the part. We havde hade this problem on 2 PC(10%) so far that i know of..., it show the standard steel color as a dark gray when you open the part .. but show the right color in the iam files. We are wokring on a fully update Inventor 2024
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
SBix26
What lighting style is the in use in the assembly file?  Same in the part file?  If not, that would be the problem... set the assembly file to use the same lighting style as the part file.
Sam B
Inventor Pro 2027 RTM | Windows 11 Home 25H2
rosie_lucas1
Hi @Darkforce_the_ilogic_guy
I wanted to check in and see if you saw @SBix26  follow up questions and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Rosie | Community Manager
johnsonshiue
Hi! As Sam already mentioned, this is most likely lighting style related. I suggest you standardize the lighting style that all users should use, since the active lighting style is stored in the iam/ipt file. You may want to set the desirable lighting style in the template files.
Many thanks!
Software Test Engineer
