inventor imports a 3d models in inches when they should be mm
Message 1 of 9
i have a part i want to import but when i do, inventor does it in inches so instead of the length being 250mm, it imports to 250 inches. how do i change it to mm so onventor changes the size and not just how the units are displayed? the file type says it is a 3d model from third party.
Replies (8)
Message 2 of 9
Cadmanto
Welcome to the forum.
After importing it, you can change the units as I show below.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
JDMather
Attach original file here.
Changing document units AFTER import will not change geometry size.
Direct Edit>Scale.
Message 4 of 9
i have tried that but that is only to change the unit measured in. lets say the part is supposed to be 200mm long, it is imported as 200 inches. i need the part to not only measure in mm but also change the current properties as mm. hope it makes sense.
Message 5 of 9
JDMather
Import or Open?
Document units before Import?
Attach original file here and end all doubt.
Message 6 of 9
this the part as i got it
Message 7 of 9
JDMather
See Attached.
Message 8 of 9
mcgyvr
Press the options button before opening it..
Change import units to what you want..
Message 9 of 9
thank you.
